Old 04-05-2009, 07:19 PM   #1 (permalink)
booblinker is on a distinguished road
Default 2" body lift question
Do you need to move the radiator, or extend the fuel filler hose? I have a 2" body lift off a blazer, and I was going to use the pucks off that, and some bolts from the hardware store. Just wondering if I am going to need to fab anything else up.
booblinker is offline   Reply With Quote
Old 04-06-2009, 01:01 AM   #2 (permalink)
Unbolt the MAP sensor when you raise the body and make sure you are not over-extending you're brake lines and any other wires. ALong with shifter extending! I would use redlock-tite on the bolts (personally, once all in place). Sometimes does the fuel filter hose need to be extended and I am not sure about the radiator, rubber flexes so it should do so.
CodyJ is online now   Reply With Quote
Old 04-06-2009, 08:39 AM   #3 (permalink)
sidekickguy's Avatar
sidekickguy is on a distinguished road
the radiator should be attached to the frame, so you shouldnt have to worryabout that. well it is on mine anyways
1994 Sidekick JLX
4x4 manual hubs
5 speed stick shift
1.6 L 16 valve
sidekickguy is offline   Reply With Quote
