Could not find the administrative tools on my own post; the tires on craigslist were sold.
I have read everywhere a 235 is the biggest possible but on my little 95' Geo it shows 195 on the side of the frame and am curious if I could actually run these with no lift and such. It will be on a 2wd model tracker.
Reason: The tires were sold...
first q: is on road , off road, or both,?
if used on road.
next q: is what rim width.?
if OEM size, , 135s cause the tire to deform and crown in the center (quote top 10 timer makers) (rim is too closely spaced) [ i just corrected this }
so car will be twitchy on road, hard to steer. requiring constant correction
and poor braking directional control
drawing body parts is the least of the issue.
the tire manufacture has table for this and you can ask them.
the big tire shops will answer way better than me.
Jerry, pretty much looking for cheap tires with decent on-road abilities. I think 95 could handle 215 okay; but it just looks lower than my other one with the amount of lift the 4x4 one has.
i think this is true. 215 should be ok. (ok , tire likes rim. but hit wells ,?)
the tire stores will not answer because of law suits,etc.
but the facts are on the tire makers pages, after all someone must engineer them in . right? ( hint, they even have weight , pressure tables ! )
if you like brand xxxx, go to brandxxx.com and read.
the full tire spec is there, and the min rim widths, etc.
if it rubs ,thats YOUR problem.
only you know what springs are on car.
many of these cars have B&G springs, or the like for lift.
some have 2 inch drop, yah , that is right.
tires are complex and way out of my area. but is do know enough, to be careful.
You need to do your homework.
what car, what mods have been done (still finding them on mine, ouch)
the door frame tag means nothing if you run oversize tire.
so to go yourtire.com and look up the weight pressure tables.
would a Jeep pattern bolt up with a 92 Geo tracker?
its the same 5bolt universal pattern isnt it?
the suzuki bolt pattern is 5x5.5 some jeeps have this as well my friends wrangler has this bolt pattern as well as a older ford ranger also has this
__________________ Now
New Chrome Grille
Sliverstar Headlights
Bajha Fog lights
Kc Daylighters
All Desert camo interior
6 Speakers
2 12"inch Kicker comps Subs
1 1000 watt Mtx amp
Custom slim box to fit in the back
Sony Deck
Xm Radio
Tom Tom Navagation
Custom Intake and Cone Filter
K&N Oil filter
1.5inch coil spacers lift
Rock Crawlers(crome)Cragers
New 30 inch tires
so i can possibly throw a set of jeep rims and tires with spacers and a 2inch body lift.
was wondering incase i came across a job up here in stagnation county of Pennslvania.
thank you =-) id hate to go to a junk yard pick um up and be screwed.
I myself have never done much research.... but this may help some people. I too am looking for rims and Jerry thats expensive for TIRES! I had 4 for $65 on craigslist but someone took two of them already and I wanted a matching set!
