I had my 93 4 door sidekick quit starting on me. the starter wouldnt turn over. nothing. (acting like i have not pressed the clutch pedal all the way) I was able to push start it fine it ran. I assumed it was the starter or clutch safety switch or something electrical. I also noticed i had low fuel so I topped that up and now its acting fine, starting no problem. Heres the question. If i was able to push start it and run it but starter didnt even try to turn over how is that related to fuel level?
Could be bad wiring, starter, relays, switches... sometimes starters appear to be flawless but can suck all the batter's voltage and won't turn the engine over or even click the acuatator because it sucks power and internally shorts.
above works? or not ? (starter test it is)
and battery is dead the next day or while driving , you loose power,
like energizer bunny, beating drum slower and slower
you have
bad Charge system
if battery drains sitting parked in garage?
you have a Phantom drain. (see my dark current page)
