no. (?)
89-differences
corrections, see diff page.
see my parts finder page.
its there.right.
how-to-find-EFI-parts
see this photo
your ISC is rotated 90 deg. and is no different. (ignore looks of it)
i use the old name in my suz book , iac. (other books call it isc.
idle speed controller or idle air controller, same0same0.
the other iAC is the coldstart air controller thermal.
the Dash pot is the coldstart fast idle valve.
on all 8v there are 3 air control devices and work diff. complex it is.
ISC is the highest one of the group
bottom ,of TB is cold start Idle air. 100% thermal and closes hot.
Dashpot is , open at start and closes in 5 to 30 seconds. ECU controlled.
Dashpot is closed 100% time hot and running, if not it is bad. ask how to fix.
last is the ISC (on top highest point of T
it is used for a host of things.
Idle speed at all times.
fuel cut.
Egr tests. and many other things. but idle is #1
if the TPS switch closes ,at idle the ecu says , enable idle speed control software.
it then starts pulsing the ISC.
this pulsing holds the idle at 800 rpm under all conditions,
but AC on and PS overload.
under AC on , ,it raises idle to 1000 rpm.
that's the kit and cahboodle.
there is a Idle bleed screw for setting idle.
If you pinch the top tube of the ISC,
mine drops to below 800 , as it should.
next , FSM words.
apply 12vdc to the ISC , unpluged, at the IAC itself.
and then disconnect the 12v.
you just switched from wide open to wide closed.
the idle should go to above 800 , then below 800.
if not, there is a serious problem with idle.
you see why?, if you can make it work correctly , how can the ECu?
once you get to this point, you must then find out why?
air leaks ,bad ISC.
bad motor. ( can be manifolds ,etc vacuum varying, compression issues ,suck valves)
or ecu in limphome.
or TPS not signalling IDLE at ALL.
TB = Throttle body
