Old 04-02-2009, 07:17 PM   #11 (permalink)
Jasenford is on a distinguished road
well i see the IAC but i think they are different from the 91 and up becuase i dont see the bleed screw..
also i dont see a hose coming from the IAC, just the electrical connector... Is that right?
I did the 12V into the connector and heared a noise but when i started it, there was no change in the idle.
What would be the easiest way to find a vacuum leak in the hoses, beside buying a vacuum guage?
When i tried to adjust the TPS with the OHM meter the numbers would pop up then go away and i would wait about 10 seconds before the numbers would show up again... i was doing it with the key on but not started, and put the meter on pins C and D and it showed about 150-170 ohms... am i doing this right??
89 Tracker 1.6L 8V 5speed 4x4
CA, USA, flowmaster muffler, cold air intake, Pathfinder AT 31x10.50.x15 Tires
Jasenford is offline   Reply With Quote
Old 04-03-2009, 12:44 AM   #12 (permalink)
i just seen the video of the TPS adjusting on youtube so now i think i might have an idea
here it goes
to adjust it, the car has to be on and the dashpot has to be in, therefor that would be the time to check the clearence between the screw and dashpot which would be like .02MM or .04MM..
now im not sure about adjusting the bottom screw for the idle, i dont know if the car has to be on or off to adjust it, but after that is adjusted then you go and start calibrating the TPS..
Does it go something like this, cuz i sure hope so
Old 04-03-2009, 02:07 AM   #13 (permalink)
no
id say never adjust the bottom screw. says it in red letters in the FSM.
and that is not an idle screw, its a factory setting for mininum air to the engine.
once you mess that , there will be no help from any books.
we only adj. the air bleed (see cover of rubber plug , just behind fuel pressure regulator.)
remove plug this is a idle speed air bleed screw.
the TPS is always first.
setting idle when the tps , switch in side it , is not closed, is a total waste of time.
above is my link to TSP calibration. did you see that.
this isc is the same, on yours its just rotated, that's all. don't let that fool you. it is just a solenoid air valve ,the body shape means not a thing.
http://carfix.stufftoread.com/fresh-...inj-view1w.jpg
see it there in red words, and my wrong spelling of RPM. ouch.
the fule presure reg mounts over it and blocks it from view, but look carefully.
it is there.
on a 8v we always pinch every vac,hose to see if rpm drops.
anythat cause that are bad.
cept: ISC top hose, and PCV. hose.
no leaks are allowed,if you have leaks ,setting idle will be a waste of time.
TPS working.
no leaks.
then set idle.
its kinda like bailing out a sinking boat, better is to find the hole and patch it.
nature abhors a vacuum.
Old 04-03-2009, 02:18 AM   #14 (permalink)
id did say one thing wrong,on 89
there is no water tubes on ISC and has no outside air tube.
air is feed internally to the iSC.
so testing it becomes much harder.
only way is to remove it and clean the ports.
and to unplug conn, to it and put it back and see the effect it has.
Old 04-03-2009, 12:18 PM   #15 (permalink)
ok i see what your talking about now as far as the Bleed screw, ill check out the TPS adjustment and Calibration again and see what happens
Old 04-03-2009, 01:05 PM   #16 (permalink)
the 8v cars are all tricky on idle.
if ecu is happy and not in (failsafe or Backup)
http://carfix.stufftoread.com/ECU/fail-safe.JPG
if it is forget idle and work the real problem.
keep this in mind on all 8v
on 8v , the Map runs the show(rare to fail) and if there is any air leak , any at all
the MAP finds it and adjusts the AFR (airfuelratio) perfectly (ecu does this really)
and the result on any 8v is a higher idle. [ and FULL POWER }
the idle is special on these old buckets.
the idle is comprised of the following factors:
1: Buttery fly plate stop screw (a factory minimum air , never to be changed)
2: IAC (bottom TB ) cold air valve (100% mechanical wax pellet) closed hot.
3: Bleed screw on front center of TB. ( idle setting hot screw)
4: ISC ( or as i call it IAC-E for electric) this functions both hot and cold.
5: illegal air leaks.
6: The Dash POt (on inside left TB ) called the Cold start air valve (30seconds of screaming it causes at cold start , hate mine)
7: and last of all YOUR right foot is the huge air leak. (but really #1 too)
the 16v is missing #6 and goes lean with leaks.
the 8v just loves air leaks.
you can climb a mountain with a good air leak ( see #7)
This car is a Speed Density system. (no MAF)
one more other factor can come to play?,
there can be sludge packed below the butterfly plate , wrecking the the calibration !
of #1 above. Ask any Ford or Jeep owner. (grin)
it prevents the plate for fully closes or simply blocks normal flow.
As you can see the air induction side is complex.
#6 is easy , if it don't retract , it is bad. easy as pie to check.
on any 8v , it is best to :
check vacuum , to see that it is steady, if it is not, the EFI will go nuts.
check hoses for leaks. (i pinch them , no idle change)
every single hose gets pinched, then is say to self, is this idle drop ok?
PCV yes, ISC (91 and newer) yes, Brake booster no, all others no.
but the MAP hose needs to be TEST physically tested, because if you pinch it you starve it from vacuum, and it ?thinks OMG, WOT (wide open throttle) (rich happens)
when I say IT, i always mean the ECU and the sensor , acting as a servo.
almost every map hose after 15 years. melts and cracks. so visual , test it.
and vacuum test it. make sure vacuum reaches the MAP (melts inside too)
keeping 15 year old vacuum hoses, is really just a waste of time and pain. IMHO.
each car can have 1 problem or more.
id check vacuum first.
a bad engine is well, a bad engine.
not knowing vacuum and compression on any badly running engine,is being blind.
PS:
more toxic soup
if the min, air supply is not supplied in certain modes,
the ECU goes crazy (no really) and hunts the ISC.
hunts. yes, it goes HIGH , then low , then HIGH over and over
the idle. trying in vain to find the 800 rpm sweet spot.
a clogged up Dashpot ,vac. nipple will do this, as will a collapsed vac, hose to same.
we suspect there are many fail modes to cause ISC HUNT.
too many permutations of fails to test.
just inplug the ISC, if the hunting stops
you know why, right. ECU is just trying to unstick the silly
nasty ISC.
this shows a SMART ECU, is working and so is the iSC.
together.
Old 04-03-2009, 01:41 PM   #17 (permalink)
well i tried to use the OHM meter on the TPS and i only got resistance from the B and D terminal and the C and D and the other terminals got none, does that tell me that it is a bad sensor?
Also i wish i had a camera but the idle bleed screw i think i see has either a metal or plastic cap inside the hole and i cant seem to get it out, but i looked all around the TB and seen that that was the only hole you could be talking about
i will buy a vauum pump guage and see how what the pressure is at..
The other bad problem i did when i first got the car was i did mess with the buturfly screw and never counted how many revelutions i turned it =(
i read the ECU page u showed me, and do i disconnect all the sensors but TPS and see if it starts?
Old 04-03-2009, 02:16 PM   #18 (permalink)
i just did a compression test (with engine cold) and here are the results
#1 150
#2 145
#3 140
#4 150
Also would i be able to put a 94 tracker TB on mine, with all the 94 components.. IAC, TPS
Old 04-03-2009, 02:44 PM   #19 (permalink)
dont pull all sensors, that is just a proof of how limphome and backup work.
IT DOES: (a new page)
Failsaft now what?
how ever pulling one sensor, can tell you about mixtures.
if car is lean, pulling a sensor can force it rich, proving the theory. and a problem?
good compression. a good motor. same as mine cold ( i get 155 but guages not that accurate)
no ,the 94 TB is bad for 89 ECU. vastly diff. in flow and function.
if you unplug ISC , what is the effect on idle.? running.
what if you hot wire ISC , with 12vdc , idle speed, running, not ISC remove,just conn. to it. (that is the FSM go , no go test on ISC)
dont feel bad about adjusting the TB stop screw.
the HAYNES rag, says to do that , well , they mix motors and really mess up
they mix the carbi Samurai with Kick EFI , showing you to adust the idle
with the screw on plate and show the wrong photo of TB. ouch. 89-98 is lots of variances. they dont say that or show that.
id dont have 89 fsm , nor a photo of the front of the TB on 89.
wish i did.
how many ohms, the ohms is crutial.
A to D 3k- 5k (5000 ohms is 5K)so 3000 to 5000 or as the fsm page link i posted shows.
The above is the end to end measurment.
C to D ,must be below 500 ohms mine is 50 ohms, KEY OFF , unplugged
then when you open the throttle the C to D must go higher and higher or to infinity quickly.
that completes the switch side.
now the POT side.
IF A to D was good above ,the pot resistor is no cracked in half. good. not infinity.
then B to D,
it will read low, very low as the pages show. then as you move Butterfly valve with right hand, see the OHMS rise from low to high.
it can go to near 5k, or near what A to D read. but never greater.
that is only a variable resistor, just carbon and a gold slider.
just like Journey to the bottom of the sea, the book. Pots everywhere, is my joke.
Before electronics and digital,all ran off POTS.
i will look for more 89 stuff later
Old 04-03-2009, 02:50 PM   #20 (permalink)
got this hole, see screw, remove black rubber plug from hole first.
neither 91 or89 parts list show this rubber plug , but it is there, on min.e
