Old 04-01-2009, 04:24 AM   #1 (permalink)
elonja's Avatar
elonja is on a distinguished road
Default rear washer line
can anyone tell me how to get to the rear washer line?its blocked and i know for sure its not the motor,cuz i put the front lines to it and it works fine,pulled that little panel by the door in the front and water comes through.so if anyone has schematics for the 94vitara,1.6l 16v i would greatly appreciate it or info on how to clear that blockage.
elonja is offline   Reply With Quote
Old 04-01-2009, 08:23 AM   #2 (permalink)
rickf is on a distinguished road
Default washer
When mine quit working i tried all the same things you tried,swithing lines,pumps etc. Still not working. What I found was the line to the rear has a one way valve in it. On my 93 kick, this valve was located under the washer bottle. I just pulled it out and spliced the line,voila, works now
rickf
rickf
Current 2000 Tracker 2L 5 speed 4 door 4x4 103K
Previously owned 92 JLX 120K,93 JLX 230K,93 JLX 156K 96 Sport 135K
rickf is offline   Reply With Quote
Old 04-01-2009, 02:43 PM   #3 (permalink)
TheZuke!'s Avatar
TheZuke! is on a distinguished road
What little panel by the door?
I pulled the rear wiper/motor from a '97 Geo and installed it
into TheZuke!
A couple weeks ago I pulled the spray head from the Geo
before they crushed it.
The hose from the back door to the passenger lays behind a sheet metal
panel covered by the head liner (not easy to access)
Removing the spray head from the Geo almost destroyed it.
If you would like to remove yours, here is the procedure as best as I remember it.
First remove the rubber washer between the spray head and the body.
It will stretch enough to fit over the spray head (maybe not if it is cold).
This will let you see the notch in the hole cut in the sheet metal and the
spring tabs on the spray head. You will need to compress the tabs and
rotate the spray head because there is a tab on the inside you will need
to get out through the notch. It will be difficult to rotate the spray head because the tubing doesn't allow much movement.
The tubing is attached to the spray head, since I was not intending to re-install the spray head into that particular vehicle, I pulled on the tubing
and about 4 feet came out with a hose coupler on the end.
That's about all I know about the rear window washer.
Oh, I've had to replace the Y-connector on the front washers because
it deteriorated.
And check the electrical connections at the pump motors, if they get corroded, you won't get much pressure from the pump motors.
Good Luck!
TheZuke!
1994 JX 4x4 16v 5-speed 4-door AC
TheZuke! is offline   Reply With Quote
