Old 03-30-2009, 09:52 AM   #1 (permalink)
komobu is on a distinguished road
Default Pulling Engine Codes from a 90 Tracker
Hi;
I just got a 90 Tracker. It was built in July of 90. It has a distributer w/ Vacuum Advance. The Check Engine Light is on. I had the battery disconnected over the weekend and the CEL is still on. How can I retrieve the codes without a scan tool? is there3 anything to jump?
Thanks for any advice
komobu is offline   Reply With Quote
Old 03-30-2009, 10:28 AM   #2 (permalink)
Gallery: 10
HotTommy is on a distinguished road
First, look for posts by jtgh and click on the link to his site. There's a world of information there. Second, if your 90 is like my 89 you retrieve the code in two steps. First, put a fuse into the bottom most location on the far right of the fuse block by the driver's left knee. That is the diagnostic port on my car. Then turn on the key and look for the CEL to flash the code. If it flashes once, pauses and then twice, that is the code for 12. Count the flashes and you'll know the code.
If the CEL just stays on all the time, it may be the mileage sensor that is reminding you to do preventive maintenance. There is a hidden switch that must be moved to turn off that light. On my car the switch is behind a small panel directly beneath the steering column. I can't see it, but if I slide my hand into the opening palm down, I can feel it. There's a photo on jtgh's web site.
HotTommy is offline   Reply With Quote
Old 03-30-2009, 11:19 AM   #3 (permalink)
Blinking-Lamp
Click on check engine lamp.
Thank Jerry.
Old 03-30-2009, 01:47 PM   #4 (permalink)
Thanks for the info.
Where is the DLC? What does it look like?
Old 03-30-2009, 01:59 PM   #5 (permalink)
On my 95 it is in front of the battery, on my 97, it just behind the passenger side headlight. It should have a little rubber cover over it for protection.
Old 03-30-2009, 02:46 PM   #6 (permalink)
Found a white 4 pin connector with a rubber boot over it. There are three wires, Black, Blue w/ Yellow stripe, and a Purple. Which ones get jumped?
Thanks for all your help
Old 03-30-2009, 03:37 PM   #7 (permalink)
Check Engine Lamp stuck ON?
Look at this link and find the 4 pin connector & jump B to C.
Old 03-30-2009, 04:36 PM   #8 (permalink)
is this car a EFI , electronic fuel injected car 8valves
or is it a CARB.
i guess its carb, same as suz, but i have no GM books that old.
89 has a DIAGNOSTIC JUMPER FUSE.
above left knee.
the one you mention might work too.
using the 91 rules. in my page.
but the fuse works best
as does the dome fuse for reseting codes.
Old 03-30-2009, 04:41 PM   #9 (permalink)
http://carfix.stufftoread.com/ECU/diag-conn1aw.jpg
may work.
but fuse jump for SURE works on all 89's
Old 03-31-2009, 05:53 AM   #10 (permalink)
Thanks! I found it!!!
