Old 03-06-2009, 03:27 PM   #1 (permalink)
Jasenford is on a distinguished road
Default 89 tracker 8V TPS issues.. need help
i recently took my motor out and had to take the actual TPS off... i wasnt able to disconnect it.. now im not sure how it went on., i didnt know it was spring loaded.. when i put it on, the throttle plate opens a significant amount, i tried adjusting the idle screw to see if the plate would close, but only closed a little bit... now im stuck
plz help
thanks
Jasenford is offline   Reply With Quote
Old 03-06-2009, 04:27 PM   #2 (permalink)
that was a big mistake , adjusting the throttle plate screw. its a factory adjustment
that balances the IAC idle controller to the center of its range.
i guess instead of unplugging it , you just unbolted it. ?
no big deal that, but don't mess with throttle screw unless , last resort.
here is mine, factory set and painted white.
http://carfix.stufftoread.com/fresh-...rfly-gap1w.jpg
89" i don't know the gap. (helppppppppp)
TPS testing
since you wrecked the idle, now the TPS can not be adjusted.
the tps is set to 0.020" of idle preload.
the buttery gap is 10 times that.
ouch.
in the old days,
back in carbs and wooden hulls.
they taught in school. (trade auto back then)
always count the turns to the stops before adjusting anything.
so
if you want to undo something you did wrong. ,you can.
a regression path.
we now have that gap logged here for all cars but 89/90
91 to 95 , 8v and 16v we have it.
have a starting point, is everything.
Old 03-06-2009, 05:01 PM   #3 (permalink)
randy h's Avatar
randy h is on a distinguished road
Jasenford, you may be interested in bidding on the 89 Tracker Factory Service Manual linked below. That might provide some of the info you need. It is listed as buy-it-now for 15 dollars plus 6 dollars shipping.
I am not affiliated with seller, just trying to help.
eBay Motors: 1989 GEO TRACKER SERVICE REPAIR MANUAL OWNERS BOOK (item 380105917271 end time Mar-23-09 10:06:26 PDT)
randy h is offline   Reply With Quote
Old 03-06-2009, 05:21 PM   #4 (permalink)
i looked at your TPS site a few hours ago and i couldnt really comprehend what i needed to do, i dont know why, i just... i seen there was a test were the car does not have to be on but you can uplug the sensor... would there be way you can tell me what to do in a more understandable way lol sry
Old 03-06-2009, 05:21 PM   #5 (permalink)
i looked at you TPS site a few hours ago and i couldnt really comprehend what i needed to do, i dont know why, i just... i seen there was a test were the car does not have to be on but you can uplug the sensor... would there be way you can tell me what to do in a more understandable way lol sry
Old 03-06-2009, 06:19 PM   #6 (permalink)
the buttery fly sets the the min. air flow. at Idle.
it is set at the factory.
the tps is then set with the preload mentioned.
http://carfix.stufftoread.com/TPS/TPS-p92.jpg
note top data box , one is feeler gauge 0.008 and the 0.016" go nogo is the procedure.
the purpose of all this is to get the TPS switch to close every single time the throttle is dropped to idle, ( if not the ECU autmatic idle never wakes up, and stays dead , no idle controls)
to do this and not have the idle fail every other time.
they preload it. ( diff. from 0.008 and 0.016)
they place a 8 thou feeler guage in the stop screw, boss juncture. per my photo above.
then adjust the tps, so the switch just barely closes (reading less than 500 ohms)
typ, is 50 ohms. (need resistance meter , ohm meter to do it)
then you lock the screw down on the TPS base.
then you insert the 0.016 feeler gauge in the same point and make sure the
switch goes to infinity.
(TPS is UNPLUGGEd, during all adjustments of TPS)
if the switch fails to open,at 16 thou, then you set the tsp wrong at step 1, you over corrected.
if you set the tps to open too far in the throttle angle , a flat spot will happen
in the transistion to off idle. ( that is because you might be exiting Idle at 2000 rpm and that would be bad, "IAC hunting results")
now, since you modified the idle stop screw, you now have to do 2 things at once.
not easy.
set the idle, to the proper 800 rpm with this stop screw , HOT.
while keeping the TPS switch closed.
The duty cycle set up does that. setting the duty cycle , gets the IAC valve in the
so it can lower or increase idle as the need arises.
You could follow this path:
1: short the TPS switch pins, some way. (perm. idle)
2: set idle hot. 800rpm , accessories off.
3; set Duty cycle per book.
4: calibrate TPS switch as shown above and above link.
5 : test IDLE by , throwing on head lights, fan, defrost (not A/C).
if idle holds at 800, then iAC idle controls are working. Trumpets!
6: turn on A/C note 1000 RPM.
hope that clears up an complex subject.
Old 01-27-2010, 07:50 PM   #7 (permalink)
PARKRAT's Avatar
PARKRAT is on a distinguished road
Do you still have the pic of that tps? please it wont come up with the link.
PARKRAT is offline   Reply With Quote
Old 01-28-2010, 05:47 AM   #8 (permalink)
TPS testing
and here's a photo of all sensors:
http://www.kick-fix.com/TBI-1w.jpg
Old 01-31-2010, 01:01 AM   #9 (permalink)
kick-fix's Avatar
both 8v and 16v (not 1.8L)
all set same why.
with 3 feeler guages.
only diff ,is gauage size and pin names.
if you set it correct the idle switch will always close at corrent moment.
if that happens idle controls start working.
EG: on 91+ cars, throwing on the HL and heater fan(head lights sorry) the RPM holds
at 800 rpm hot.
this is CONTROL. OF IDLE AND is done by ECU and ISC control valve.
one some years. if the TPS idle switch fails ,the freeze timing features will fail.
and idle duty cycle setting too can fail.
that is the rops.
my TPS cal page is on the fast sensors testing page.
click on the photo of the TPS.
Post your car spec!, what ARE you driving?
96 Tracker, 5sp, 2Dr,4w,d OE stock.Fed48+No A/C ,No Cruise. +MPG gauge. a new 97 today 2wd 4dr
I do not advocate of shot gunning or guessing or working with out tools/meters/scopes
but I will help you the best I can! I can't see or hear/feel your motor, so consider my answers, in that light.
There are 2 diagnostic paths, one with tools and one without! Please advise which path you wish to take?
Old 01-31-2010, 08:48 AM   #10 (permalink)
PARKRAT's Avatar
Check engine does not come on, i got this 1989 1.6 efi automatic two weeks ago, the idle surged from 1200 - 1800 all the time, it had been messed with by a goof, so i turned down the idle screw 4 turns and now it runs smooth no serging, it idles at 1100 when hot, 1400 when fan or lights are on, injecter makes loud noise when lights are on, the paint on tps is broke so its been messed with, burns no oil leaks a little, mpg is 17, just put plugs cap and roter in yesterday. Any help is greatly appreciated.
1989 GMC TRACKER SLE, 1.6 8V TBI, AUTOMATIC, 4x4, A/C, POWER BRAKES, BRAND NEW I PIKES , 2 DOOR TIN TOP, 3RD OWNER.
