Old 02-25-2009, 01:11 PM   #1 (permalink)
kakemann is on a distinguished road
Default Sidekick\Vitara slipping in turns
After blowing some life in my vitara i have put on some bigger tires. Theese tires are a bit old.
Now when i go around turns it feels just like the back weels are loose from the bolts and the car is moving from side to side when i turn. This only happen in moderat speeds( 10 -50 miles, and on asphalt.)
I do highly suspect that the dampers and springs are not good.
I have checked the tire bolts, and removed the bolts on the drum and everything is nice and tight.
Any other ideas or tips on how do solve this problem?
kakemann is offline   Reply With Quote
Old 02-25-2009, 08:15 PM   #2 (permalink)
it could be , rack it and inspect the drag links and the top (above 3rd member)
axle mounting pivot frame for rust thru or beaks.
rack it and pry all with a long 2x4" see how things flex. dont be shy
Old 02-28-2009, 11:49 AM   #3 (permalink)
Draglinks inspected, and found to be in a somewhat ok shape. They are abit rusted but not to bad, and no breaks. I replaced the shock absorbers and it got abit better. Will try some other tires one later on to confirm that it was the absorbers in combination with the tires.
jtgh: Finaly found my camera charger and allso found a transistor vendror so i will send you some pics on the euro ECU and hopefully a "how to fix a broken injetor ECU" if i can get it running with the one im repairing when i get the time.
Old 02-28-2009, 01:21 PM   #4 (permalink)
your doing good , thanks for sharing.
