you should be working in close contact with a pro machine shop.
1: he measures your bores for dia, outof round and taper.
2: he proclaims (its is guarantee and craft) you need xx over size for me to guarantee good bore and hone.
3: you get the pistons he recommends,
4: you give them to him and he measures them exactly.
5: (gives the Nero thumbs up) and the bores it perfect the specs are published in the FSM. rebuilding the engine with out this document is folly.
put the machine shop in the loop , full and complete and the results can be amazing.
this is a craft not a swap of parts.
the machines knows what he can do, what his equipment can do.
i do not understand your reverse rebuild process. what method are you following.
what is your goal, a good running engine.
more power,
turbo prep.
really what is your end point.
every one has diff. goals.
street strip, offroad crawler or ,just something to fool with in the sand or dirt.
ps,
the markings vary by manufacture, go to there web site and find it,
if it is not there , cantact them. im sure their anwer is easy to find.
