sure as my link shows.
if the TPS is lying its booty off , the ECU can not tell if the throttle is steady.
all sensors must be good and no air leaks, in induction or exhaust blockages is the
prerequiste for running the EGR test.
a bad TPS,can:
cause the EGR monitor to FREEZE ( i call it stall) the software just waits forever for you
to stop wiggling your foot (created by TPS noise)
or
the monitor starts and tps messes up the results.
THE egr test is an advanced monitor.
It uses the MAP sensor to detect an exact amount of manifold pressure drop , at the
moment the ECU POPS open the EGR main valve.
it it dont see the exact minimum drop in vacuum( increase in pressure is what MAP does) then the monitor fails.
(drop ,rise, dont let that confuse you, your vacuum gage will drop, but the map shows and increase, that is because IT measures absolute pressure, where a vacuum is 0 inches)
Look at your weather barometer, it works just like the MAP.
WOT = zero vacuum or max BARO MAP pressure.
we think the pressure drop (vacuum) is 6 inches minimum but SUZ does not tell.
6 inches is an industry avg. best i can tell.
Alldata might have the exact num for each car, but they no longer have a single monthly subscription option, so heck with them. "greed"
stall test.
does it pass?
