first off:
the clutch can go bad , many ways, yours is dragging which is the direct opposite of slipping. they can grab , chatter, collapes and lock, and and disentagrate. (and more)
so lets stay in the drive way. if it dont shift there, it is bad. K.I.S.S rule. LOL.
Either you are NOT engaging a gear, or it is grinding, 1 or the other.
if it grinds it is a clutch issue, if you can engage, it is a shifter issue.
when in the drive way. you depress the clutch pedal and it has trouble entering first gear? or any gear for that matter. ? not moving just parked.?
if that is true at any level?, any grinding at all, then the clutch is not completely disengaging. (for any of the many reasons they do that)
Trouble shooting:
all clutches:
adjust the play is to spec. (always forever first)
if after adjusting the play, it still drags, then step 2 comes next.
2: someone pushes pedal ( I will assume here the pedal is fully retracted by the spring)
and press the pedal from top to the bottom floor boards.
while doing that someone else, is under car. looking at PN 19 (see photo) and holding
a simple ruler next to it with one end pressed to PN 21 bracket.
this person measures the full stroke of part 19, exactly.
bingo, you now have your answer.
if it moves at least 1 inch , the cars clutch linkage is good.
if it does not, then the clutch or tranny is bad.
BODY problem, or trainline problem ( the problem is instantly cut in 1/2)
cool huh?
next answer shifter
the shifter when removed, has 2 plastic parts on the end.
1 is a concave washer
2 is the tip guide.
both must be good, #2 is critical to shifting, if it is missing , shifting will suck.
point 2,
this portion of the extened gear rack is not lubricated by the tranny lube.
It is isolated. and you must assure it is lube your self.
look , access condition, take action.
if dry . lube it, if dirty clean it/and lube it, if well lubed, leave it alone and do not remove good lube.
that is the first steps.
see part 19 and 27 both are high fail items .
http://carfix.stufftoread.com/tranny/shifting/rails.JPG
you need to exactly specific what the gears do , good and what the do bad.
if part 27 is broken, missing etc, (link above)
Rev. and 5th will be hard.
