i bet it rooled over and is 140k. 2k a year is very low) mine rolled and shows 65k
"unplugged the iac, it runs fine."
Did this cure the miss or the the hard start.?
the iAC , works under all modes.
cranking it opens fully to allow fast idle and proper mixture.
and for idle.
and for deacceleration air cut
cold start fast idle too.
unplugging it , cause it to open tad. allowing more air.
if the Iac is stuck or commanded closed, during start, it will be a hard starter.
tune up , = rotor,cap, wires and plugs? at least?
i bet dollars to donuts, you have at least 2 problems on this EFI system.
common other fail is ECT sensor, Engine coolant sensor, with 2 pins.
if it reads, higher (ohms) it will force a false richer starting , AirFuelRatio .
The other fail coud be the fast idle dash pot not opening when cold.
look on side of TB(rear) see dash pot, see it hold open the throttle?
it must. or starting will be real bad.
your car has 5 paths of start air. ( all 5 contribute to a good start)
missing on 8v engine is almost always.
bad tune up, cap rotor wires and plugs.
or running lean,do to fuel pressure too low. (among many )
