Old 12-06-2008, 07:04 PM   #1 (permalink)
arod_12 is on a distinguished road
Default crank shaft
I have heard that you should not turn the crank shaft counter clock wise. Why is that, Does it do damage to the engine?
arod_12 is offline   Reply With Quote
Old 12-06-2008, 10:49 PM   #2 (permalink)
where you hear or read that.? and how would you , when you shouldnt.
it does on engines with , varialble valve timing gear mechanisms.
if you turn the crank bolt CCW, it comes loose. bad.
if you reverse the battery ,it blows the ECU to kingdome come.
remove tranny and turn flywheel backwards. , who cares.
if you have a 16v there 1 is one other restriction.
do not turn the crank or the cam with the Tbelt is removed.
also there is a correct direction to turn the crank when tensioning the Tbelt.
in what context are you talking.?
