Old 12-02-2008, 10:22 PM   #1 (permalink)
LongRod's Avatar
LongRod is on a distinguished road
Default Antifreeze/coolant
Should I be using green antifreeze/coolant containing silicates or silicate free orange antifreeze containing organic acid corrosion protectors? Can bad things happen if the two types are mixed? What type of antifreeze is "GM Specification 1825M?"
LongRod is offline   Reply With Quote
Old 12-03-2008, 04:42 AM   #2 (permalink)
Ahmed_1990 is on a distinguished road
mixing coolents can actually be fatal to your car, if you mix the wrong stuff you will gell up your system, basically ur radiator will have jellie in it....
and i suggest using good old green coolent, but make sure it there is a different cooler coolent in there that you flush it out.... hope i helped
Ahmed_1990 is offline   Reply With Quote
Old 12-03-2008, 03:07 PM   #3 (permalink)
shortbeagles is on a distinguished road
Yes, absolutely don't ever mix the two types of antifreeze. It will turn to jelly in your cooling system. Make sure what you you currently have in there now and replace it with the same.
shortbeagles is offline   Reply With Quote
