100% huh, LOL hahahahahahahahah .
Oil on plug , on the inside or the outside?
without a tech1 scantool, there will be not be fuel trim pulls. right? Show me.?
try finding one? (i have a 5 auction filter for them for 2 years, none yet)
Check Engine Lamp stuck ON?
why look at the lamp glowing? SES [service engine soon) is a mileage NAG light. reset it.
reset the SES slide switch and then look again. Still glowing ,then pull the code with a simple paper clip.
NOX.
many a bad running car , is hidden by a really good CAT.
air leaks, (lean) , bad MAF.
Using Gas Analyzer Readings
good luck.
