I've got the Tracker up on jackstands and the wheels off, looking over what I need to do to bleed the brake lines. In the FSM the last bleed is the LSPV.
Where is the elusive LSPV (load sensing proportioning valve) located?
I slid around under the Tracker tonight with my flashlight, following brake lines from the rear drums to the master cylinder but didn't spot it.
91 Geo Tracker, 8v, 1.6L
2 door, 4WD, Automatic
