fuses dont mean squat. why would the design 2 fuse boxes. kinda expensive.
Master cylinder (front end, line ports)
non ABS has , 2, , 1 up , 1 left)
ABS has 1 , up.
huge modulator unit to left of MC
also elect wire to each brake mount , and tone wheel on each rotor.
back to brakes.
what parts were removed?
MC, did you prebleed that , as it said in the new box or rebuilt box. and method?
the above can not be skipped.
The whole deal:
using a vac bleed tool ( harbor freight $30 or less , nice brass tool)
bleed , LR , RF, and the LF. (RR has no bleed on manY a kick)
run half a quart thru. (the trick here is ignore bubbles, as youll get them falsely,ok?)
(90% time , i have perfect brakes now)
10% solution:
then bleed again old fashion way , 2 man bleed.
look now for bubbles.
if that dont work ,get a pressure beeder or make one.
have plans. and email them.
nothing better, in the world.
