A Jimny axle probably won't be strong enough, the diffs are small like a 410 and ratios will most likely be wrong. The Jimny also has vacuum operated hubs, although manual FWHs can be fitted. The Sammy axle has been used with wheel spacers but isn't really all that strong stock. If you really want to go SAS then Toyota axles front and back are the best solution.
