» Sponsor Links
»Garage Storage and Cabinets
Old 11-17-2008, 09:14 PM   #1 (permalink)
hialtitude's Avatar
hialtitude is on a distinguished road
Default interior lights and horn quit
Using information I got from this site a while back, i was able to fix my light problems. (I was motivated to write this by Bex who posted "lights and horn won't go off!!" )
The chassis ground behind the left tail light looked ok, and was tight. I removed it, cleand the terminal, the area where around the screw hole, and the underside of the screw head.
Re-installed everything with dielectric (sp?) grease, and viola! Everything worked.
I also removed the door switches and cleaned them, and the interior light assembly.
I hope this helps someone to save time if they have the same problem.
Having fun turning money into smoke and noise!
hialtitude is offline   Reply With Quote
Old 11-19-2008, 07:49 AM   #2 (permalink)
Thanks for your post! I had a bare wire that was shorting out in the engine compartment so I found my short easily. I have often heard about the importance of this connection at the left tail light - chassis ground? So far I have never had to do anything with it, but it is good to know, and probably look at and clean, as a preventative thing....
