» Sponsor Links
»Garage Storage and Cabinets
Old 11-11-2008, 10:10 PM   #1 (permalink)
johnnydice is on a distinguished road
Default Shifter problem
hey all .
I have a 1996 suzuki sidekick sport . i have a problem with the shifter .. won,t come out of park Unless i open the side panel push the release .. then hold my foot on brake at same time , now , The guy at shop says has something to do with the alarm ? i can,t see that being it .. but any how tells my daugther inlaw to shift use her finger in the hole LOL anyway what would be the problem is theres something broke off inside? a sensor? a switch ? what would stop this shifter from moving into drive ?
thanks for any help i can get ..
Diceman
johnnydice is offline   Reply With Quote
Old 11-12-2008, 04:56 AM   #2 (permalink)
rdycus2 is on a distinguished road
I fixed this problem on my 2005 Forenza by popping up the plasic plate on the shifter that has P N D 2 1 on it. Underneath is the shifter mechanism. The PARK sensor switch is on the driver side of the shifter mechanism. I cut out that switch and shorted the two wires together with a wire nut. The releases the PARK lock, releases the ignition key lock and on my car kept the battery from being drained because the ignition key could not be turned into the OFF position.
rdycus2 is offline   Reply With Quote
Old 11-13-2008, 12:48 AM   #3 (permalink)
jtgh's Avatar
Default shift lock
hi
there are 2 issues. no starting (cranking ) blocked by shift PRND321 switch down under. on tranny.
and the brake park lock out solenoid.
2 cures. mechanical or electrical. x2
apply power to the solenoid full time (ignition on to > the solenoid)
or repair the brake interlock it self. ALL.
or the mechanism could be bad, bent, broken parts on solenoid.
it is up to you how to do this.
my leaning, if it were mine is to put a hidden switch that applies power to the solenoid , for emergancy usage.
course my mix , will require fixing solenoid if bad.
i ask my self do i want my car defeated by the piece of junk? no way.
so i have cheating device.
imagine being stuck far from home and in a very compromising situation.
IMHO.
last is to render the solenoid inop by bypassing (mech) the lock completely.
we have posters here that reported all these ways.
my wifes lock EMG switch is hidden in the center tray console, out of sight.
hope that helps and blow up.
click me.
Old 11-13-2008, 09:41 PM   #4 (permalink)
hey thanks guys
The problem was the shifter cover wasn,t set back in position . i know .. never seen anything like it . the sligthest movment of the cover causes the solenoid to kick back , and you have to use the reset . on the side to reset .. was a simple fix of 4 bigger screws . but here a tip make sure you reset before placing the shifter cover back on . this silly but simple thing cause all that problems .. thanks guys , this job Marked DONE!!
Old 11-14-2008, 12:38 AM   #5 (permalink)
jtgh's Avatar
thanks for tip on reset , some cars dont have it.
happy trails
click me.
