there are 2 trannys auto, on licks, (and vastly different)
what car , what year, what tranny you have (oops got PM its a tracker)
you could greatly help buy telling what the gear shift says.
PRND321 or PRND21 ? ( my best guess at label.) 3speed or 4 speed , BIG DIFF.
Better. (no suzuki's can do)
then open the glove box , see inside,see DAH build sticker.
this is called the "GM RPO build sticker"
many 3digit codes. ( for every !!! option on car)
see about ? line 3 , about first code MXn (MX = auto tranny)
the code MX1 = 3speed 3L30 tranny. 3L= 3speed longitudnal, 30= load rating.
yours will say MX1 or some other MX, what is it.?
that 03-72LE is the tranny makers code and that is a 4 speed.
a 4 speed will not work on a 3 speed car ( you never said) unless you make major harness changes (in cab too) and install a TCM tranny puter. ( at the least !!!)
__________________ http://carfix.stufftoread.com/
click me.
yours is a 2 door right? 92 tacker 2d, 4wd, auto 3sp. rag top.
I only know it takes (at least)
new dash harness for 4 sp.
new tranny harness and TCC harness.
new TCM (transmissioncontrol model)
possible a new TCC relay.
new 4sp tranny, maybe mount changes ,
may be prop shafts , for sure ,just checked.
new shifter
new console
new park lock out, and complexities of that , snowballing.
cruise control? , i wont go there.....
it would take me 3 hours to look it all up in the parts lists to see the diffs.
mixing years, is suicide for the harnesses,my guess.
the 4sp mostly fits in 4 door heavy tin tops. ( thus the heavy rating)
the 3sp most fits in 2 door light canvas tops.
the harness are completely (mostly) different in these cars. 2 vers. 4 door.s
i think your 3sp is used on a VAST number of cars world wide.
it should not be hard to find , did you ask a wrecker to cross it.
3L30
BTW the 4sp , shift manually pefectly with the TCM remove, just no auto.
(it goes in to manual test mode , when the electronics goes belly up)
great trick if tranny acts wierd ,just pull TCM conn. and drive another 100k, manually.
good luck.
click me.
Well, from what I have read online mine is the 180C-3L30, I will check out Barlows tommrow to see if they still have that one listed on car-parts.com. I'm not going to fus with all the harness and stuff. Better off to but a newer tracker than mess with it.
God Bless,
Joe
