the CEL must come on KEY ON. no starts
if it dont , 1 of 3 problems
1: loss of power to ecu
2; bad ecu
3: bad lamp
the CEL on , at key one,signals, I am passing my self tests.
if you see it not come on .
chcck , lamp , and the fuse to ECU (including the dome memory fuse)
also once on
pull the codes , see if you can get code 12
if you get no codes, then again , bad ECU or loss of power to it.
replace the cap shown here.
c103
My ECU is bad, now what?
they go bad easy, replace it before replacing ecu , far faster to do that as exhange can take 2 weeks on fleebay.
any one with soldering circuit experience can do it, ham radio guys ! yah.
The main relay must pull in every time, if it dont ECU will be useless..
If you suspect Main output failure ,just wire in a cheap lamp to the node.
then watch it, (#194 lamp is good)
if it dies and light dies, you found the reason. (MAIN DROP OUT)
keep an open mind, most fails here , are random.
top is bad wiring.
corrosion of connections
bad c103 ( replacing fixs most flaky ECU's)
bad main relay
bad wires to main.
corrosion to bottom of right fender main fuse buss ( note HEAD lights dropping !)
alarms wired in to critcial ECU circuits by numskull PO's
same for remote starting. why risk primary circuits for that BS.? (bull squat)
YOu need to watch the CEL lamp , key on , and running.
do you get ECU code 12 by placing the paperclip , high tech code scanner??? lLOL
