» Sponsor Links
»Garage Storage and Cabinets
Old 11-03-2008, 08:31 PM   #1 (permalink)
Hunting Dog is on a distinguished road
Default 1997 tracker no spark.
I bought a 97 4 dr 4 WD tracker the crank was shot. I replaced the crank now I can not get any spark? it ran before I pulled the motor. I have no manual does it have an alarm system that I need to reprogram? please help!!!
Hunting Dog is offline   Reply With Quote
Old 11-03-2008, 11:41 PM   #2 (permalink)
jtgh's Avatar
97 1.6L ??? or 1.8L ???
NO SPARK , and does crank briskly.
this motor, i shy at answer here as you didnt give engine displacement.
i will answer for 1.6L as it is the most common.
if it had an alarm you would kown that right? it would have an enable switch in car.
first off , do not work on any car with air bags. until you learn the disable procedure.
they can be lethal to mechs.
on this motor there is a cranks sensor CPS on the bottom front of oil pan, connect it.
click me.
Old 11-03-2008, 11:50 PM   #3 (permalink)
jtgh's Avatar
Have Distributor yes = 1.6L
no dizzy, but have coil on plug 1.8L.
also ,shooting from hip again , no country stated.
in usa/canada, we have OBD2 ECU.
connect any full scan tool and watch the sensors.
RPM cranking,
TPS below 70% (foot off gas)
Check engine lamp on?
dtc p0010 thru p0020 , is cps fail (crank position fail or cam sensor)
p0320-323 same.
tell more.
click me.
Old 11-04-2008, 09:15 AM   #4 (permalink)
no alarm, 1.6 with distributor. Minnesota, cranks very nicely. checked the crank sensor removed wiped clean and reinserted still no spark.
Old 11-04-2008, 09:50 PM   #5 (permalink)
jtgh's Avatar
Default exact dwg s
yours has the integrated Dizzy .
cmp, ignitor , coil and cap and rotor.
all in one.
this one takes more patients to troubleshoot
i presume you have a fresh cap and rotor. as they are so cheap.
2 down 3 to go.
i will send you the schematic.
here below
the tests for this all in one, are hard and convoluted.
id see if a cap and rotor fixes it.
then open it and look for loose things, correct them.
look for burning on the coil.
if it is dead ,then get one at a wrecker.
or some stores have exchange rebuilds on these.
see attachment.
if you want we can walk thru each section testing.
click me.
