» Sponsor Links
»Garage Storage and Cabinets
Old 11-01-2008, 10:51 AM   #1 (permalink)
Jlaudio12 is on a distinguished road
Default I have another Problem
Ok I got the Tracker lifted Widened and 31/10.5 rubber Got pulled over for Fender Flares not on, So i did the Big truck 1.5Inch flares and they turned out great. I went for a ride, Put it in rev, and POP the signal/reverse fuse poped changed it and the blinkers worked till I put it rev it did it again , Where on a 1989 2 door does the wire come from to activate the rear lights, I might have grabed it with a screw and shorted it out,
Jlaudio12 is offline   Reply With Quote
Old 11-17-2008, 06:36 AM   #2 (permalink)
brucebolivar's Avatar
brucebolivar is on a distinguished road
Wink
I'm a little late, but the wires run on the left side of your tracker. I would check the left rear fender flare you put on. If you take off your rear left cabin panel, you may see your problem. Its tight to see, but it could narrow it down to a screw or two.
brucebolivar is offline   Reply With Quote
