Old 11-01-2008, 07:59 AM   #1 (permalink)
Default Viton o-ring source
I have searched and found that the distributor o-ring failure is common, which is now my problem. I guess this question is directed to jtgh as he referenced the viton o-ring in a previous post. Do you have a source, size and/or part number for these o-rings for a 1.6, 16v? Thanks in advance. Also, in a previous thread, you requested input on the 1.6, 16v throttle body to throttle body plate clearance, when closed, as measured with a numbered drill bit. I have cleaned two throttle bodies (both from 95's) and found zero clearance. In fact, the plate shut so tight that when cleaner was sprayed in, it held the solvent like a soup bowl. Fantastic Japanese machining.
Old 11-01-2008, 08:40 PM   #2 (permalink)
Order Viton O-Rings
i have a better one but cant find it now.
Old 11-01-2008, 08:43 PM   #3 (permalink)
http://www.suzuki-forums.com/suzuki-...y-o-rings.html
16th hit on viton
1st hit viton source.
Old 11-01-2008, 08:47 PM   #4 (permalink)
MarkB : photos : Tracker Disty O-rings- powered by SmugMug
and the unbelievable beautiful step by step guide.
Old 11-02-2008, 07:50 AM   #5 (permalink)
My error, I searched for "o-ring" and not "viton". Thanks for your help
Old 11-02-2008, 12:55 PM   #6 (permalink)
no prob. that source i found was out of 100 ww.
and they do not rip you off
my comment was to help others search it out if land here.
if you buy a 50 cent o-ring on ebay they will charge you $10 to $20.
plus shipping, ( cost them $1 and charge you $8) Ebay can stink.. YMMV
Old 11-13-2008, 07:16 AM   #7 (permalink)
20081112161951057.pdf (139K
Hopefully this image is usable. I don't know if this has been addressed before but in my 97 FSM for a 16v distributor case, when replacing the O-ring, silicone sealant needs to be applied to part of the case, see fig 47, lower right hand corner. When I removed the dist. case from my 95 16v, it also had risidual silicon at this location.
I guess I'm going to have learn how to post images. LOL
Old 11-13-2008, 12:40 PM   #8 (permalink)
add reply button, not fast.
then fill out words
then scoll down see manage attachments.
browse , upload it ,close.
done.
silicon sealant, has many types.
all O-rings , must be installed with Silicone grease not sealant (sealant is a caulk)
the purpose (many) is to prevent mangling the seal on insertion. (no puns ok)
im making a hard to find parts page this week.
Injector seals, O-rings, theromostats for 1.8L
please do not forget to mark the dizzy in 2 places before extraction.
rotor to body lip and dizzy mount screw to base.
being at TDC 1 is really help full.
this dizzy leak fools folks into thinking they have a VC gasket leak.
that document , does it mention pn and brands.
if yes, try this cross refr from suzuki.
http://carfix.stufftoread.com/tools/...nts-subs2a.pdf
Old 11-13-2008, 12:56 PM   #9 (permalink)
1342b? Three bond
a large tube is $8-25
but pillow packs can be found at any hardware store, worth their salt.
good mfg.
Dow 111 O-Ring Lubricant - 5 Gram Pillow Pack
good: source: at 72 cents.
Amazon.com: Dow Corning 111 CMPD 6G VALVE LUBRICANT & SEALANT: Industrial & Scientific
Old 11-13-2008, 02:41 PM   #10 (permalink)
see former post. jtgh thanks for your help.
