Old 10-27-2008, 11:46 AM   #1 (permalink)
-Lawless is on a distinguished road
Default Battery light coming on
Well the Tracker is not done with me yet.
Now that I have everything running perfectly and passed emissions, a new problem has arisen.
My battery light comes on if the idle is below 2000 rpm, above that it goes out.
It dims from bright at low rpm's to off at higher rpm's.
I recently power washed the engine and I'm thinking it could be the connectors going to the alternator and I'll check those today after work. I suppose it could be I got water in the alternator but I tried not to.
I'll take the car to Autozone and have the battery and alternator tested before I replace anything but the rpm thing leaves me to believe it is a connector or voltage regulator perhaps.
Any other ideas?
'90Tracker 8V 5spd man. soft top
-Lawless is offline   Reply With Quote
Old 10-27-2008, 01:16 PM   #2 (permalink)
that's the charge lamp.
1; fan belt slipping
2:battery terms rusted or the other end and big solenoid or that ground to starter bolt loose.
3: bad battery
4;bad alternator.
id clean the batt, terms first with that fancy brush tool thingy.
the put that nice anticorrosion red treatment on it.
connection,. then test battery or try doner battery.
Old 10-27-2008, 03:18 PM   #3 (permalink)
I blame Suzuki gremlins.
Light went off and didn't come back on.
I'll do the cleaning anyway and hope it never comes back.
Thanks Jerry!
Old 10-27-2008, 09:07 PM   #4 (permalink)
water in the ragulator, or soaked brushes of the alternator slip rings.
I think you baked it dry.
i think you are a good to go
happy trails.
