Old 10-25-2008, 12:34 PM   #1 (permalink)
lyrinosis's Avatar
lyrinosis is on a distinguished road
Default A Tea Kettle in my Engine
1989 JLX 1.6, 5 speed 4wd, 2-door tintop 1.6L TBI
going 95 kph on freeway, suddenly, a whistle like a steam kettle. lots of steam.
turned engine off immediately.
oil looks fine. no rad fluid. little pools of coolant on top of engine.
starts fine, runs great cold.
how do you start to look for problems.
I think it might be the thermostat sticking closed... any other suggestions?
lyrinosis is offline   Reply With Quote
Old 10-25-2008, 02:02 PM   #2 (permalink)
cold
pop hood (bonnet)
start it and just stand there and watch for 10mins.
the answer might be real obvious.
see water pump spraying.
see hose spraying
even the rad can crack a tube and spray fluid. ( mine did in May)
it is under pressure 12 -14psi when warm and this fact will make finding the leak real easy. let it tell you.
if this don't work , then a new cap and thermostat.
Look in RAD is the liquid green and clean or do you see black carbon dust floating and or oil signs? (head gasket)
explain no rad fluid.? please.
does that mean, none in overflow bottle or none in the radiator with cap off COLD !
over-heating-why?
do a compression test.
