» Sponsor Links
»Garage Storage and Cabinets
Old 10-24-2008, 07:10 PM   #1 (permalink)
cobumski is on a distinguished road
Default installing rear main oil seal 16v geo tracker
Quick question as i do not want to pull engine again . I have the engine out of my tracker and I want to repalce rear main oil seal . I have pulled the seal retainer from the engine and pushed the old seal out . To install new seal do simply put the seal on the crankshaft with rear of seal resting flush against block and reinstall retainer or do i pre press the seal into the retainer then install seal and retainer on block and crankshaft and if I do pre press it into the retainer, how far in do i press it and ho wcan i be sure it not slighly cocked in retainer. My manual just says install rear seal. Thnks in advance cant wait for the snow but want to get mt engine in!
cobumski is offline   Reply With Quote
Old 10-24-2008, 10:17 PM   #2 (permalink)
jtgh's Avatar
yes, put it in the retainer. for sure !
of course the manual shows a factory tool to do it.
with a proper seal driver (same size of seal but ever so slightly less.
oil the seal lips and crank.
drive seal into housing until flush with out side edge, no more.
it must not be canted.
out of FSM, (paraphrased)
click me.
Old 10-25-2008, 08:04 AM   #3 (permalink)
Default Installing oil seal
thanks very much i would have done it wrong, so i just push it in from outside until flush and im done, if u come to colorado i owe u beer or beverage of choice thanks you
Old 10-25-2008, 04:08 PM   #4 (permalink)
jtgh's Avatar
thanks
im so paranoid, i glued mine in with the same stuff suzuki uses to seal a transmission case
i felt it didnt fit tight enough to make me happy.
Smash Glasses.
CHEERS.
click me.
