96 1.6L 5speed , 4wd Right? Auto or manual locking hubs, what do you have? I see a later post and it implies manual locking.
You did the below and the front prop shaft spins so... (shifter is bad) { cross fingers}
below is the test, that you did.
one tire off ground front (you have limited slip so one tire only)
transmission in 1st gear. hubs locked.
only 1 tire. off ground.
4wd engaged, H or low , try both really
grab CV, if it turns, the Xfr case is failing. (assmues 3 wheels on ground and trannylocked to flywheel.)
cant turn it , then go to other side and repeat the test 3 wheels on the ground.
if automatic tranny I am not sure how to do these tests. (park locks front .so....)(for others, maybe some one can tell me...?)
yours is 5sp.
