1999 two door tracker Door lock Electric?
Hi I just bought a 2 door Tracker with a 1.6l Fuel injected Engine.
it has two coils mounted above the Valve cover and 4 individual Injectors
I can not find the Engine in any Book either.
The Doorlock is not working, turning the Key in the Door will not move the button up or down.
I removed the door Panel and found that there is some sort of Motor or solenoid attached to a Rod that goes up to the Lock.
I dont know if this is an aftermarket device operated by a Remote or if it is a Factory standard safety lock. It seems that the Motor or solenoid is seized or was left in the Lock position.If I remove it from its bottom of door mount everything works. there is a red and a blue wire leading to the solenoid and the solenoid or motor has 12vdc printed on its plastic case.
I know that the Car has an Alarm as there is a Horn mounted under the Hood but nothing seems to activate it. Have not traced the Wiring yet.
This seems to be a Oddball Tracker not a Vitara but resembles the 2000 series Trackers without the 2 litre engine.
Professor
