hes is just playing word games.
all these 1.6L kicks 8v and 16v have real dizzy.
in the bottom of the dizzy is a CAS or cam angle sender.
in 89 this part is called CAS buy SUZ
later called CMP (95 manual calles it that, see DTC 42)
then ISO standards renamed it CAS.
this is a 1994 8v , it is called the camshaft position sensor in that year.
the stator is the metal star wheel that triggers the CMP.
the CMP is just a hall effect sender,.
I even have a full schematic of it. here.
http://carfix.stufftoread.com/IGN_ti...IZ-CAS1W86.jpg
it generates a 5v sqaure wave, it it is dead, there will never be spark.
it can be tested with a voltmeter ( and helper to crank) (fsm method)
or with an LED + 500-600 resistor .
or with a scope (or DSO)
it can be tested in or out of circuit.
It is possible too , to make the coil spark with the ECU unplugged.
both tests prove the outside of ECU parts are good and that the ECU is bad.
CMP:
using a back probe method
probe the signal out of dizzy.
as you crank it will toggle from 0v to 5v.
http://carfix.stufftoread.com/IGN_timing/CAS-91.jpg
actual scope view on a real 8v kick.
scope, led or meter, this one can be tested
but there is ONE trick,
you can not disconnect the DIZZY during the test.
the DIzzy needs power and ground to function and the output must have a pULL up
resistor ( the dizzy output only opens and closes and NEVER sources power)
this fools many people.
to test it on a bench,
connect power and ground to a 12vdc battery (any) and then connect the output
to a >>> plus lead(long) LED ,then LED to Neglead short> 500ohm resistor and then to +12vdc battery (same as battery pin +)
twist dizzy shaft,see LED blink.
the led test is close best because , simular current flows mimicing ECU.
but the scope is the best because its rubber meets road. No changes in circuit.
we can test it ,what you got for tools
some later kicks use a fully integrated Dizzy , cap, coil ,cmp,ignitor. 96+ i think.
and yes, it can be tested the same way.
on the 8v ,it is just a TDC sender, to us humans.
