Old 10-20-2008, 11:04 AM   #1 (permalink)
ben95 is on a distinguished road
Default Exhaust manifold 1993 - 8V
I need a exhaust manifold or headers that fit on a 1993 Suzuki Sidekick 8 Valves
One of the three little stud on the manifold is broke.
If somebody have one or a headers for cheap please contact me. (In good condition)
I need it before winter.
I live in Montreal, Quebec, Canada, H1W 3T9
contact me by email please: benimarti@hotmail.com
Thank you very much
Ben
ben95 is offline   Reply With Quote
Old 10-20-2008, 11:51 AM   #2 (permalink)
Do you have AutoZones in Canada? I know they carry replacements. Do a search for Dorman parts. Good luck
Old 10-20-2008, 09:23 PM   #3 (permalink)
dorman has a new one for $99
i ground mine flat the broken stud.
then
center punched it.
then drilled it out with a 1/8 th inch drill bit.
then I dilled to the tap size that matched a new stud bought from auto store.
then i tapped it .
then i put in new stud.
luck has a play.
Old 10-21-2008, 06:50 AM   #4 (permalink)
jmcquaid's Avatar
jmcquaid is on a distinguished road
I have had good luck with right handed drill bits to remove broken bolts and studs and Calmini has a header exhaust package to fit both 8 valve and 16 valve models.
J
jmcquaid is offline   Reply With Quote
Old 10-21-2008, 01:54 PM   #5 (permalink)
i bet 10 to 1 the Easy-out(tm) snaps.
left twist drill bits are ok. but are no panacea for this stud, IMHO.
the best tech. is getting perfect center and working out the drill size 1 at a time
using a numbered drill set. (dead center a must)
with manifold on the floor or in a vise.
keep working the size out , when you hit root size (look up metric size see tap size)
Machinist Metric ISO Screw Thread Tap - Drill Size Chart - Engineers Edge
those studs are put in extra tight and will be siezed ofter 100k mi.
( i suspect suz factory spot welds them in , but not sure
on 2 of mine, i did that and when i hit root, the stud was just a coil, i grabbed it and
it pealed out like a spring. saving the threads.
those Calmini headers will cost you.
one more trick is heating it (the stud) and then spraying your fav. penetrating oil it.
repeat 3 times, pray the vacuum created , sucks some in side.
but on mine no way Jose'
Ymmv..
I wouldnt give up until the header was cracked in half. LOL.
another tactic is to drill it and tap it to the next Metric or ISO USA inch standard thread.
which ever is smallest.
or
drill it to the HELicoil size that fits. (this will weaking the tiny mount)
dont forget you can sell the old header on ebay. ( and subsidise the new one)
id buy it.
Old 10-22-2008, 11:23 AM   #6 (permalink)
thanks everybody I found a used one for 50$ at the scrap!
