Hey,
I'd done my fair share of research into this problem I've been having. Almost narrowed it down to the alternator/alternator belt till I seen another thread on here talking about the water pump.
Anyways, its a 1995 Tracker, 16V, 3spd Auto 4x4, 107K miles. Recent maintenence:
-Timing belt changed at ~96K. THINK all other belts was done too.
-Full tuneup (wires, plugs, and all the good stuff) done at ~101K
-Last oil change at 106K (do it every 2500 or so)
- Full front end brakejob at 106.5K
It has a REALLY nasty squeal it likes to make at me at the most inopportune times. Been doing this for about a year, itll be real bad for a few weeks, then nothing for a while, then come back. To me, I think it sounds like a squeaky belt. It usually tends to happen in either cool weather (mornings), or in wet weather (during/ after rain it is REALLY bad). It does it when I fire it in mid-afternoon after it's sat all day (FLorida humidity?), but its very short lived and stops once i shift it from park to reverse then to drive.
In the mornings, it will squeak as long as i keep my foot on the pedal. It goes with engine RPMs, when the tranny shifts, it quiets proportionally. It will squeak up to 55MPH then it will usually cut off there. I can sometimes stop it by letting my foot off the gas and coast until the RPMs drop, then giving it some gas. That works about half the time, The other half the time, I shift from Drive to neutral and back and forth from LOW to NEUTRAL (at slow speeds- 10mph) until it quits.
One reason I think it's the alternator is because right when i fire it, I can start driving and sometimes it wont squeak. But if I turn the AC on or hit the air horns, it squeals, even without changing the pedal pressure at all. Once its warmed up going down the road, I can turn on whatever i want and there's no problem.
Wondering what y'all think I should look at first. I plan on changing the belt first, as its most cost effective. It don't look bad at all (I think it was changed 10K ago, and looks about on par with that). Then I;ve read the whole alternator can be out of whack.
P.S. I think it has to do with the alternator belt because a quick blast of belt dressing before going will keep it from squeaking when it usually does, or quiet/shorten it significantly.
Places I;ve read:
Squealing 16V 1.6L...but the belts aren't loose?
http://www.suzuki-forums.com/suzuki-...ternators.html
