http://carfix.stufftoread.com/ECU/P&G.JPG
here is the power pins that must not be overloaded. test them carefully ,
some dmm has analog graph to see if the voltage is glitching.
(poor mans scope)
the fuel pump is infamous for that trick, but that is not the only load.
on yours you need to test the coil, done.
and make sure it is not grounded out!
the internal coil can open, or short (not you) and can ground out.
every time the ecu first the IAC (70 times a second) it overloads.
the ecu can not drive a grounded out IAC,
normal IAC current is on the order of 1/2 amps.
The FP relay comes on for 3 seconds,each key on, and every power bump.
ecu might be rebooting do to overload and you hear the FP relay click in.
this is maybe the 25th posting of ECU overload here in 2 years.
the biggest fails rates were.
fuel pump
chaffed wires.
rusted connector on fuse panel.
bad ecu.
you are first with potential IAC ground out.
my mind is open, it can be many things, as this buss connects to many things.
the power buss that is. shown in the schematic i posted.
simplified 8v..
http://carfix.stufftoread.com/Schem-...-1991-jtgh.jpg
ECU b1 and b7 must not be overloaded nor any actuator output line of the ECU.
