classic lean problem.
but it can be many reasons.
bad fuel pump (very weak)
stuck open Fuel pressure regulator (rap it with the back side of a screw driver might unstick it for 1 day or so)
gross induction leak, ( vacuum leak)
or a bad MAF.
since it fails (bogs) hot and cold , i must presume the engine gets hot and ECT is reflecting that heat to the ECU. (ect is electronic water temperature)
I'd first measure fuel pressure.
The ECU is programmed to expect this to be perfect, if not , mixtures will be bad.
my PUmp page shows the hard data on that.
click below sig. click pump link.
the adaptor for measuring fuel pressure is $10 see link to supplier.
on a the 16v one needs an adaptor .
some here ( not me) pinch the return line for a second or 2 and see if power returns.
if yes, pump pressure is bad.
pinching the return line , puts heavy stress on the pump (shunt test) and must not be done more than say 10 seconds.
however getting to the return line under the intake man is hard.
Fuel-pump-testing
see tool 2267 link.
btw: many kicks have a rusted fuel pump ground wire behind the Left rear tail light.
id make the baby clean and shinny and the grease it.
can cause dead pump, weak pump and intermittant pump.
easy to inspect too.
see wire lug at 2pm attached to body there.
cheers
