Have had this sidekick for about a year, regularly maintained.
Last week was heading out to work, cranked and started fine, when I went into reverse it died, put 'er back in park and would no longer start.
Much of the information is being passed on to me as I've not been the one doing much of the work, but so far:
No spark
Sufficient power TO coil (tested)
Replaced coil with known working one, still no spark
Tested ECU (swapped with another known working one, still no spark)
Fuel Pump tested (and relay pulled still no spark)
Replaced dizzy with known working one still no spark
Timing belt is not damaged
Spark plugs/wires are new, replaced last month and has run fine until now.
Battery tested/replaced with new one, still no spark.
Checked all grounds, looked for corrosion/obvious wiring problems, nothing seems apparent.
Have had my brother-in-law who specializes in sidekicks/trackers for the past few years look at this, he's worked on dozens and he's baffled, worked on it for a few days so far, can't figure it out.
Like I said, has a strong crank but won't spark.
Any suggestions would be greatly appreciated, and if any additional info is required I will try to provide asap.
Hope I'm not forgetting anything
Thanks!
