I have a 1989 Suzuki Sidekick whose rocker panels were damaged during an off-road hunting trip. The rocker panel is part of a larger quarter panel that includes the door frame. It is Suzuki part #6451160A30 and costs about $347 from
Suzuki Dealer | New Cars Weatherford | Fort Worth Suzuki | Used Cars Weatherford. The quarter panel is labeled 1-2 at the bottom of this photo:
I believe that replacing the damaged rocker panel with a genuine Suzuki part ensures that the trim will fit perfectly on it. I don’t want to buy cheap after market rocker panels that must be drilled to add brackets for the trim. The trim will never fit properly on these after market parts. I know because I had that done on one of my rocker panels.
To save labor costs, my local Suzuki dealership’s body shop wants to cut off the rocker panel from the new quarter panel and replace only the rocker panel. The body shop claims that replacing the entire quarter panel is expensive because all of its spot welds must be drilled out. You can see the spot welds by removing the weather-stripping around a door frame. The labor cost of cutting off and replacing only the rocker panel is lower. The body shop claims that there will be no structural compromise due to the Sidekick’s sturdy inner frame.
I hate to buy an entire quarter panel only to use the rocker portion. Are there body shops equipped with tools that are able to more efficiently remove spot welds without extensive manual drilling? Can the spot welds be snipped off?
