when doing the plug spark test use a fresh clean plug laying on the valve cover and to spark plug #1.
the wet plugs can short the energy inside the internal insulator cone.
ive seen carbon tracked rotors so bad ( hidden too) to the inside center dizzy shaft.
all energy going down the shaft and not to the plugs.
you dizzy might have my completely mis-timed.
if the rotor is not aligned to the post in the cap, at 5DBTDC, THEN the spark just dont happen at any plug, even thought the coil made 50000 volts.
ecu is happy.
the test spark plug can be any heat range , just clean and fits.
dizzy:
crank to #1 TDC 5deg. before (left looking rear of car ) on scan of timing cover.
there are 2 TDC's on is exhaust other is compression stroke.
blow air in to spark plug hole #1 with clean hose and use mouth.
if you can blow, its not #1 , rotate 180 more.
now you cant blow.
next pull cap, rotor pointer must point to the #1 cap tower pin, exactly.
then check the timing order ,1, 3, 4,2,
How to set ignition timing
your 8valve spins CW , 1 then 3, 4, and 2. check the wires for proper placement.
get spark.
you plugs could be wet because.
1: the plugs are 100k old. and fouled.
2: dissy timed wrong, coil has park so ....
3: fuel pump regulator stuck fully closed.
looks like you have injection, and in fact you can watch it by lookiing DOWN air horn on all TBI cars.
even see the key on , pre prime squirt.
I might add, if the #2 intake is leaking badly , it will cause the MAP sensor to go quite insane, Up then down, then up then down and the ecu will go lean then rich and lean and rich. EFI hates burned intake valves ,.
you need to find the 50psi reason.
it is unlikely to get better , only worse. (that cause)
hope that helps a tad.
