here is the back side of my speedo on 2wd .
see pin A9 has no connection.(2wd)
but my 2wd vehicle harness is wired, prefect. (brown wire to supressor mod)
so swap speedo heads.
ah, but there are like 30 + diff, speedo heads.
my web site has the 4wd only list, if interested.
connectors must match.
min is 12 pin (A) and 10 pin (
my 93 is 16 x 13 pins, and will not work.
connector C is useless, as it only operates Federal 48 SES nag light.
so fed or calif heads will work. , with correct conn and counts.
Ah , here is my list
cluster-frack
