Originally Posted by Northern Suzi
I am having issues with my 1994, 1.6L Sidekick.
There is bucking action around 2000rpm and then goes away when I accelerate. No problems with starting and idles perfect. As soon as I start accelerating slowly, there is a miss and I have to give it more gas. I have changed the wires, plugs, distributor cap, but still no result. Any ideas?
You did change the rotor with the cap, right?
Other standard "tune-up" parts: air filter, fuel filter, PCV valve check/replace,
Is the "bucking" at 2K rpm in any gear?
(if it is limited to only one gear, don't rule out unbalanced tires-REALLY!
the imbalances could "harmonize" at a specific speed and smooth out above
that speed)
