Old 08-27-2008, 10:40 AM   #1 (permalink)
arod_12 is on a distinguished road
Default Heating up
Hi I own a 1992 Suzuki sidekick 8v 1.6 liter engine, with 4x4 5 speed trans I have a problem with the engine heating up. While driving for about 10 minutes the temperature gauge will start to shoot up but then sometimes it will quickly drop and other times it will take about a minute for it to go back to he normal temperature. Also when I was driving home one night I noticed when I took my foot off the gas pedal the temperature gauge would start to go up but when I started to accelerate it would drop down as fast as it rose. I don't know if this has anything to do with this problem but one day when I was slowing down when I hit around 40km/h the oil light would start flashing then it would stay on until i started to speed up again. I first thought it was the thermostat so I replaced that but it still continued to go up. I then drained all of the antifreeze and put new fresh stuff in. But still it dos the same. I read that it might be air locked and to run it with the radiator cover off. I did this, this morning and as i was watch the radiator the antifreeze started to rise and it would have risen to the point where it was over flowing so I just shut it off. I heard that if the water pump is bad the antifreeze won't go up or down. Mine goes up but it doesn't go down so could this mean i have a bad water pump or radiator. I talked to two mechanics and told them the symptoms and the both first thought it was the head gasket, I don't have milky colored oil or bubbles on the dip stick, it is not smoking like crazy, and the oil levels not going down, but it think the antifreeze has dropped a little since I have replaced it. I just pulled the plugs and they look perfect no oily of wet of any sort, so I am leaning farther away from the idea of the head gasket. But right now I am kind of stuck and don't have a clue what it could be. Any help would be great Thanks
arod_12 is offline   Reply With Quote
Old 08-27-2008, 12:59 PM   #2 (permalink)
If you had a bad headgasket, you'd know... (it would smoke one color of smoke of either white or black and have no power at all).
Yours could just be a bad pump. Although for the oil pressure light to come on, I don't know why that would happen. Get a pressure tester for the radiator. I would check to see if the thermistat is opening and if the water pump builds proper pressure and holds it, this will also see if you have a headgasket leak!
Old 08-27-2008, 01:43 PM   #3 (permalink)
Welcome !
It amazes me how much trust people put in the $3 factory termperature gauge.
16 years old too boot. ( not you, your mechs)
sorry, but no mechanic of any caliber ever pays any attention to any gauge , in the dash. ( it is just a data point, weak at best )
(well yes,after proving all is well, he will then fixes the blasted dash gauge)
I can see by your test (very good by the way) that engine is fine. (assuming complete)
1: no overheating symptoms at all ( save silly dash gauge) no knocking, or clouds of steam.
2:fluid expands as it gets hot and starts overflowing to.
3: oil light ( could be serious, or just a bad sender)
there are 3 critical paths here.
1: is engine overheating. ( Put an IR gun $10 harbor frieght , to the thermostat housing)
now look at the temperature , ahh 170 degress. (see my photos?)
over-heating-why?
http://carfix.stufftoread.com/Coolin...t-housing2.jpg
2: if not over heating you have 3 more choices.
DIY fix it. ( i have the list of checks and OHM readings to find it, at end.)
pay someone $$
3: or buy a real quality Dash guage temperature unit and install it. DYI or ?
what is best for you is up to you.
The factory guage has 3 parts.
1 the gauge ( a crude resistance heating bimetal needle )
2: the wires and connectionns
3: the sender on the thermostat housing.
anitfreeze will drop after swap due to bubbles working out.
but not after (in next few week )
PS: dont feel bad , even the Factory Service manual , FSM fails to put bad guage in the list of diagnosis of overheating. ( i guess they assume one has real overheating)
Id be more concerned at getting a oil pressure guage attached (real) to the same point the sender is attached, these cars run high pressures. (ask me)
are you running sewing machine oil in the car 5w or some such junk.
get it out of the car if you are, this engine was never designed for this oil nor is is a low mileage car , right.? want to throw a rod?
since I am here, here, is the Dashguage test for the Water tem meter , Fsm:
there are 2 tests ( 2 components, is way)
1: Guage
a: unplug the Y/w wire at sender. attach a 12 3.4w light bulb to this wire and the other contact of bulb to Ground,
b: key on , bulb will glow some and the needle will deflect some and stablize.
do not ground out the guage directly,or you will blow it up.
all it says is it must fluctuate, no other spec.
2: Sender.
unplug same wire.
ohm meter on sender term. and ground of block.
a: three data points.
122def F. 134 to 179 ohms
176d 48 to 57 ohms.
212d 26 to 29 ohms.
notice the wide range if inaccuracy of this crude instrument.? 20% ?
on the hot engine it will read between 30 -60 ohms, use interpolation to find it.
but the curve is logrithmic.
the guage is just a crude idea of the temperarture,
best is to buy , rent or barrow a real IR gauge, they are accurate to +- 1 deg. C.
that is all there is, on this gauge.
Old 08-27-2008, 01:46 PM   #4 (permalink)
if you need the value of the sender on a perfect car running with hot 195deg f. thermostat
new everything in coolant loop ,including sender.
i can provide that data point if need be.
