many folks find 2 problems , on these old cars.
yours is , :
recapping:
8v 92', weak #4 cycl ata 90 psi
perfect fuel pressure.
new cleaned and tested injector.
and noid is flashing now (was not before)
good spark and timing close to 5-8deg before TDC , good to go timing.
starts up with instant start spray !
8 valves engines one can watch injection !
and next look down air horn , it must spary fuel.
there will be no injections if no spark, but since you have NOID flashing.
the injector is firing. so ECU is happy about spark.
is the noid flashing while Injector is connected?
back probe the injector connecter with needles to connnect up , noid lamp.
id look for the spray at the injector and works backwards.
your down to 2 , probables.
1: injector wiring is open.
2: tps output tap is at 5v ( can be caused by bad ground at tps)
you see if tps loses its ground, the output pin pulls up to 5v and this is wide open throttle. WOT = UNFLOOD MODE. all injection stops.
if the NOID flashes with Injector wired into circuit and not fuel flows.
then the pressure has dropped to zero.( some fuel pumps work 1 min. then die next)
did you check the notorious ground for FP at the left rear tail lamp?
remove lamp , look in, see ground lug , it loves to rust there, causing flaky pump.
2pm position.
you might have to look at 3 things at once.
air horn injection view.
fuel pressure.
and noid.
if all 3 are good. then injector , noid lamp is lying to you.
some will flash when signal is weak.
that being the case , some folks here have wired in new injector wires from ECU to injector, just to cure random opens in harness.
one guy lost all hair trying to find that open.
we are very close.
