Old 08-20-2008, 10:25 AM   #1 (permalink)
clayrwilliams is on a distinguished road
Default Idle/Rev problems
My 91 1.6L tracker has a serious problem. When you first start it up it slowly increases idle speed until it hits 2300rpm, at this point it drops to 800 and then continues to bounce between 800 and about 1500. It just continuously revs up and down. What is wrong with my tracker?
clayrwilliams is offline   Reply With Quote
Old 08-20-2008, 11:27 AM   #2 (permalink)
TheZuke!'s Avatar
TheZuke! is on a distinguished road
Is there an FAQ (Frequently Asked Questions) for this forum?
I think Idle problems would certainly qualify?
Is there a troubleshooting chart/procedure to follow?
That way we could all be on the "same page" if
someone wrote " I followed the procedure to step A15c
(Air, Step 15, sub c) and have a false".
Or something like that...
TheZuke!
1994 JX 4x4 16v 5-speed 4-door AC
TheZuke! is offline   Reply With Quote
Old 08-20-2008, 11:37 AM   #3 (permalink)
eXpReSs's Avatar
eXpReSs is on a distinguished road
This whole forum is one big FAQ
Use the search tool and in most cases you'll find what you need.
eX
'95 Tracker LSi, Soft Top
1.6 16v Vin6 5 Speed Auto-Hubs
HALOs and CA-40g 37mpg Hwy @70mph w/ cruise
It's all in the tune up * It's not easy being green.
Drives like a grandpa due to oil prices...
uhh and is a grandpa 18 times
eXpReSs is offline   Reply With Quote
Old 08-20-2008, 03:44 PM   #4 (permalink)
racings-or-highIdle
^ I have a feeling its the IAC (Idle Air Control). Take a look at the page and try his tests.
Old 08-21-2008, 02:00 AM   #5 (permalink)
Default iac
so i took the idle air control motor off and started it back up for a quick diagnostic. leaving the hole that it covers open it idles really high, as expected and is normal, but when that hole is pluged it idles much lower but still at a higher speed than it should be. The good thing is that it keeps the idle relitivly constant now but for some reason is still idling too high, what could possibley be causing this?
Old 08-22-2008, 10:42 PM   #6 (permalink)
i bet , a bag of Freetos, you have an 8v engine, with TBI injection.
as 8v will always race with any air leak.
first pinch all the hoses close to the intake. the one that drops idle is bad.
do not pinch the PCVhose or the input air hose to the iAC as they do pass air normally.
but must not leak at hose of PCV .
throttle cable sticking , no i sure.
throttle plate below it will coke up causing plate to stick open,
the Dash pot on rear left of TB is not working ,
this little device as shown my web page , holds the throttle open when engine cranks and first starts, then it drops.
fact is it does it all the time if vacuum can get to it from the DP VSV valve.
there is a huge list for this on 8v.
not to mention ECU dropping the idle controls because it is sick or something else sensor wise is way off.
so backup 1 notch.
is the CEL lamp glowing at key on and no started. it must glow or ecu is dead or lamp is bad. (this is the ECU self test #1)
then when started it must go out. the CEL, if not you have codes.
pull the codes with a paper clip, no readers, not fancy scan tools, just a clip.
if you have 91 ,seriously consider putting in 1 to 3 new capacitors into ECU.
it is cheap and easy and all 91's will fail for this.
some (many)are already swapped out, if they are black and ugly and say Rubycon on the side they are Crap. get them out of there.
tell us about cel.
if lamp is working ok, then place the jumper and lets get out code 12.
no code 12 showing means ECU is in LAH lah LAND.
OBLIVION.
actually it is just rebooting constantly.
the IAC (control motor (just a coil) you can just unplug conn and it will change rpm.
if it dont , ecu or IAC are bad. or you hava a massive air leak.
keep in mind if you have a massive leak ,the IAC can not stop that, it can not reduce its flow enough to compensate so it will seem it is INOP,
its like having 2 water hoses running on diveway.
one is stuck on, the other one , I can't just stop all the water. see.
ok , tell me more.
