Old 08-20-2008, 09:36 AM   #1 (permalink)
JLX 1993 is on a distinguished road
Default Transmission install problem
I can't seem to put the top two big bolts... do I need to readjust something?
JLX 1993 is offline   Reply With Quote
Old 08-22-2008, 11:02 PM   #2 (permalink)
you aligned the cluch with the special too.
or is this an automatic.
Old 08-23-2008, 08:50 AM   #3 (permalink)
What's the special? I think I figured it out... there's two fittings that go on top right and bottom left engine/trans., both were on same bolt. Waiting for my friend to finish installing it
Old 08-23-2008, 02:29 PM   #4 (permalink)
the clutch kit comes with a clutch alignment tool so when you push tranny pilot shaft into to fly wheel it alignes perfect.
its special, cuz it only fits suz.
I assumed clutch was off, cuz most put in a new fly-wheel-pilot bearing and a new throw-out bearing, every time one splits a tranny from engine.
kinda like an insurance policy. High stress ,high mileage parts that fail commonly , are best chucked to curb. cheap parts , but long hard labor , next time.
that steel plate and guide bushing are a pistol to line up. and will it all at once.
so i put the bushings in the engine first.
then plate, then tranny.
Old 08-24-2008, 02:07 PM   #5 (permalink)
Tranny is now on, just gotta put the gear shifters, and gas... gas station closed right now... hope it work!!
Old 08-24-2008, 03:40 PM   #6 (permalink)
all , are crossing fingers ,
run like a cat on a hot tin roof.
buzzzzzzzzzzzzzzzzz
Old 08-24-2008, 09:31 PM   #7 (permalink)
buzzzzzzzzzzzzzzzzz
Borrowed some gas, now running, just gotta install new brake line on left rear
