Removal of front drv quarter panel in JLX
Hi all,
I have a 93 Suzuki JLX 4dr, over 200K and still going strong.
I noticed that the drivers door was sticking, and not closing properly. I thought that the hinges may be loose or the hinge pins warn. Upon closer inspection I noticed the the point on the body where the top hinge is bolted is very rusted and the top bolt is not even attached to anything anymore!
I have had it rustproofed and touched up every year at ziebart since it was purchased, which has allowed the body to stay in great shape, so I was sad to see this bad section.
Since the rest of the area seems to be in OK shape I intend on removing the door, and attaching a new piece of metal behind the hinge (and body), tapping some new holes and remount the hinge.
I have looked over several service manuals, none seem to cover how I can gain access to the back of this hinge to attach a supporting plate.
My guess is that I have to remove the front quarter panel in order to repair the cancer, is that correct, any other recommendations?
Todd
