» Sponsor Links
»Garage Storage and Cabinets
Old 07-24-2008, 02:08 AM   #11 (permalink)
jtgh's Avatar
sorry dizzy distributor,
yours is the integrated dizzy right has everthing in one unit.
ignitor, coil, cas, cap, rotor ,wires.
so a tune up , rules bad ingiter or coil.
so hot should be ignitor is my guess.
but anything is possible.
suz, dont sell the parts seperate.
coil in cap is cheaper than a whole base unit.
click me.
Old 07-24-2008, 08:36 AM   #12 (permalink)
kkiepvvessau is on a distinguished road
i guess i know what to do. i call the auto part the other day it quote me 400 for that thing.
kkiepvvessau is offline   Reply With Quote
Old 07-24-2008, 12:34 PM   #13 (permalink)
jtgh's Avatar
hope it is it, but P0300 can be many things. not just ignition.
the word misfire, can fool anyone.
evan a bloody EGR can cause it. ( indirect misfire counts)
click me.
Old 07-24-2008, 10:13 PM   #14 (permalink)
IT Not the Distributor man... i'm spending too much money on this thing. JTGH do you have a picture of the Cam GEAR the pin Lock for the cam can be reverse. it meant there are 2 hold for the pin lock . I can't think off anything except that . I might put in wrong . I put the distributor in align Cylinder 1 TDC and crank engine it will not run. The nose of the ROtor button straight up line up with the Bolt that tight distributor. I'm getting frustrate about this car.
Old 07-25-2008, 09:53 PM   #15 (permalink)
jtgh's Avatar
it sure can be, on 91 or any 8v. 16v , no photos of cog with bolt removed.
p300 can be many, many things, and not just a bad coil.
its a loss of expected power , when the ecu , expected it !! nothing more.
compression and timing of all .
you have done a strobe light at Tdc JUMPER WITH FREEZE timing jumper in place.
that might help.
see if TDC marks can hold steady?
keep an open mind on p0300.
it can be purely mechanical, or bad electronics, either side.
maybe someone here is hold 96-98 cam cog photos that are clear.
all i know is the E mark goes up.
click me.
Old 11-14-2008, 01:17 PM   #16 (permalink)
jtgh's Avatar
Default i found an accurate dwg for 96-97 1.6L integrated dizzy
here it is , file it folks.
P0300 can even be lose crank pulley.
but you can be sure it is real.
and is bad for CATtcon's
this dwg can help if it turns out to be dizzy.
click me.
