you are correct the dowel pin is very confusing but i have a picture of the thing.
here.
how-to-find-EFI-parts
see last photo i made, shows the REAL KEY is pointing DOWN !!!
do not look at the other key slot or the false rim mark at 5pm ( cute huh?)
they changed gears from 91 to 95 , to add even more confusion.
6 years.
first do not try to run it.
pull the tank, drain it first. and take it to any Radiator shop and say make like new.
you do not want all the carp that is in there , to ever hit the injector.
car will never run again correctly. (motorcycle and boat people all know this to be true)
clean fuel is manditory on EFI:
new tank, chean the fuel pump and consider a new one, 5 gallons gas, new filter,
then let pump push gas into bucket , connected somehow ? at gas fitting behind
the TB gas port ( TB disconnected ).
key on 3 seconds , off , repeat 3 times. (ecu gives only 3 seconds FP enable)
no start just key on.
now connect gas line to TB.
if injector clogs, it can be cleaned for $20 , ask me where. Professionals.
keep us posted.
cheers
