Old 07-07-2008, 12:40 PM   #1 (permalink)
longinuz is on a distinguished road
Default Brake Noise
hi every One, i have some noise on my brakes, when i turn left in about 40 km and avobe my left brake sound just like a scratching disc, same way when i turn right, my right brake souds. any help with this problem i would be gratefull.
i have an escudo 89, 1.6l engine 2 doors.
longinuz is offline   Reply With Quote
Old 07-07-2008, 11:11 PM   #2 (permalink)
Can you give a little more information? Does it make this noise when you step on the brakes, or is it just when you are turning? It could be something else, like bearings. And what do you mean by "avobe" ? I don't know what your first language is, but I've never come across that one before. Try to tell us more, so we can help. (Looks like this is your first post since you joined a year and a half ago. Is that right?)
Old 07-08-2008, 12:28 AM   #3 (permalink)
that's right, its my first post since i joined, because i was able to fix my problem with all the helpfull posts that i found. well u right my english is really rusty , well about my brakes, the noise start when i get that speed. when a step on the brakes the noise reduce a little bit but then when i step off the noise still and its an awful and loud sound. 3 months ago i change my bearings. i hope this information help you to find out what could be my problem.
Old 07-08-2008, 08:12 AM   #4 (permalink)
4.3L Tracker's Avatar
4.3L Tracker is on a distinguished road
Is the sound generated only on the left side only when you turn left and then only on the right side when you turn right? If that's the case then it sound like you may have bearing problems again because when you turn your vehical you'r aplying side loads to them.Did you grease the bearings properly when you first installed them? Did this problem show up all at one time or was it first one side and then the other?
4.3L Tracker is offline   Reply With Quote
Old 07-08-2008, 09:21 AM   #5 (permalink)
hi, this problem was it first one side then the other side. but the sound start even when i turn the vehicule just a little bit, but with the speed of 40 km.
Old 07-08-2008, 10:06 AM   #6 (permalink)
I'm not an expert at all on escudo's (we don't have thoughs over here) but I've had the same problems on other vehicals and it has always come down to bearings of one kind or another. I know you said that the bearings have been recently replaced but I would check them out again. I know you're probably like me and insist on the best parts available but that does not mean that's what the seller gives you. Also if your ride is front wheel drive or four wheel drive check your front CV joints and front drive axels. 40 kph translates into about 26 MPH , that means that when you are in a turn your bearings and joints will have a much greater load on them than when you go straight.
Old 07-08-2008, 10:27 AM   #7 (permalink)
Wow!! I just found an image of an '89 escudo....The exact same thing as as tracker. You learn some thing new every day.
Old 07-08-2008, 11:20 AM   #8 (permalink)
LOL, yeap it is exactly i think it got many names for that model. i will chake it out my bearings and see if i can find anythink, i'll be back if are not the bearings, thanks for the information.
