Here's what the 96 factory service manual says:
Tool required, TK-0-A-TECH 1 Scan tool.
Rehome procedure: (whatever that means)
1. Using a Tech1, select F5 MOTOR REHOME. The motor rehome function cannot be performed if current DTCs are present. If DTCs are present, the vehicle must be repaired and DTCs cleared before performing the motor rehome function.
2. The entire brake system should now be bled following either "Pressure Bleeding" or Manual bleeding procedure. Tracka96
